Miner
What is the Max distance you can have objects and not get a visual glitch in 3D window?
I found that if I place an object (or anything) too far from my "work area" I see glitches in the rendering in the 3D window.  I'm trying to put a simple object about 90,000 feet from my building.  This object represents a mountain peak important that is important to the design for views.  When the object is visible the model near the camera disappears as I explore.  It's as if I'm standing in a bubble with a 20'30' radius and nothing within the bubble shows up.
Has anyone else experienced this?  Has anyone found a fix?  All I figured out is that if I move the farthest object no further than 5,000ft away I get the "bubble" cutaway.
Thanks for your help!
Archicad 28 Solo
iMac 27" 3.8GHz i7
8GB RAM
10 Replies 10
Miner
Thank you!
Don't know if I can take 360° pictures but I like the possibility.
Archicad 28 Solo
iMac 27" 3.8GHz i7
8GB RAM
