What's the best way to generate trees
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2007-10-02 07:03 AM - last edited on ‎2023-05-11 12:24 PM by Noemi Balogh
‎2007-10-02
07:03 AM
The quallity, even on high settings (high dpi and high object default settings) is not very realistic compared to everything else that Lightworks renders, also the generating times increase dramatically.
I am using the default trees in Archicad and a downloaded library from the Archicad forum.
My computer specs are
2.6 Ghz processor
1gb ram
320 Gig HD
I am happy enough with the rendering times (with out trees) as it takes about 10mins for a 2000 x 750 (pixels) render at 250dpi
14 REPLIES 14
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-10-04 07:48 AM
‎2007-10-04
07:48 AM
So the major flaw in having a flat tree photo rotate to face the camera during a flythru is that it only has one sun angle that could anywhere close match the Archicad sun angle - the rest of the frames make it look like a plywood tree. Sort of like a stopped watch is right twice a day.
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-10-12 03:44 PM
‎2007-10-12
03:44 PM
Dwight wrote:I got the program, I see it may take practice.
"hen exporting the tree model to 3Ds, the user can constrain model complexity by simplifying the model and flattening leaves.
Since most 3Ds applications use a different XYZ system than Archicad, the tree model may arrive in Archicad laying down. Fix this in the 3Ds import dialog and import again.
In my seminar, [Washington DC, Oct22 - Philadelphia, Oct23 - New York Oct25 - Boston, Oct26] I suggest importing foliage as a separate object from the trunk and branches so that they can be rotated against one another to give more complex iterations [2 objects = infinite variation].
Should I wait for the seminar to ask for further exlanation on what you have mentioned above? You think you're going to be reviewing this stuff then?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-10-12 09:02 PM
‎2007-10-12
09:02 PM
This is pretty simple once you get to it, but I will add a short set of illustrations to the seminar just for you.
If you are in a hurry, try searching the Forum archive.
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-11-01 01:51 AM
‎2007-11-01
01:51 AM
Dwight, how well do the trees convert from 3ds, are you able to post a pic of a onyxtree rendered in archiCAD.
Thanks
Thanks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-11-01 02:18 AM
‎2007-11-01
02:18 AM
Here's an image of a highly-edited tree - leaf size exaggerated - and my special leaf material applied. Be sure to tell them "Dwight sent me" once you buy it.
Dwight Atkinson
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
