Wood Deck MATERIAL
Any one knows how to manipulate the size of the boards of the DECK MATERIAL?
The material is very neet, with a simple slab ArchiCAD represents the slab as 3D boards in Open GL or Internal Engine, the problem is that the boards are like 12" wide and I need to make them 5".
13 Replies 13
Erika Epstein
and the LW tab
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I tried but it stills not working. Most of the settings were the same but no 3D boards anymore... tks....
Dwight
Just to clarify, a surface texture can only create the illusion of depth, no matter what the setting.
Not that the entire computer world isn't an illusion what with all of these great things we make 'sitting at typewriter and looking at telly.'
An illusion.
Dwight Atkinson
Are you sure it wasn't some kind of slab accessory (an add on) that physically created the boards. Maybe something by Cadimage or Cigraph perhaps?
If it was definitely 3d based, try turning on all the layers in the original file and see if it reappears again. Maybe you just turned it off by accident!
