better rendering application
Which of these would you consider as better choice for presentation with archicad, artlantis studio or cinema 4d, so as to have a first class presentation and rendering. (or kindly make recomendation)
Thank you
Femi
I can't say which is better but if you upgrade to Archicad 18 you will have Cinerender (based on Cinema 4D) built-in and people are getting pretty good results with that.
I have only briefly played with it but it is much better than Lightworks ever was.
Thank you
Femi
For rendering try out Maxwell Render. It blows others out of the water. Here is just a sample and I'm by far still clueless on every aspect of rendering. I just play with settings until I get what I like
