cutting plane in front of 3d view?
I'm using Archicad 10 and lately I'm having problems with moving around in the perspective mode. It's like there is a cutting plane 20' in front of my view window. When I move forward, the cutting plane moves forward and cuts though the model like a CAT scan. Really trippy. Anyone have this issue?
4 Replies 4
Hi archanom,
click on the website below:
http://www.archicadwiki.com/Bugs/Model_cut_in_3D
go find solutions for the problem. you may find the answer from there.
Well, it sure looks like that would be the problem, but I just tried their remedy, and it didn't solve the issue. Any other ideas?
I recently had the same problem. I solved it by updating my ArchiCad version (10) in the Help menu. Also updating the graphic card helps I think.
Rafal SLEK
This bug is solved in newest patch no. 1176
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Tahoe/Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/
//MSI AMD Ryzen AI 9/2.5GHz/32GB/Nvidia RTX 5070 Ti/Windows 11 Pro
//ArchiCAD Collaborate
