Visualization
Render your model with built-in or 3rd-party solutions
glass cuttings
how can i control the size and the shape of the glass as in highrise buildigs i dont want a frame just he glass and about 1cm between glasses ,is thier a way to devide glass with it V and H , cos now i do that with using walls with 1cm thickness and glass matrial is thier any better way ? i dont want to use wall to be glass in 3D.
hana a> farhadi
1 REPLY 1
If I understand you correctly, You could use two slabs as the panels of glass and then set the 1cm apart. These can be operated on by using SEO and subtracting whatever you would like the shape to be.
