2025-01-30
05:00 PM
- last edited on
2025-01-30
11:33 PM
by
I'm freshly new to Archicad and I ran into a problem where i need to have wall connected to perimeter wall and in my country in should look like in the second picture.
2025-01-30 05:43 PM - edited 2025-01-30 05:50 PM
So its the "clean up" that your not happy with. Is that correct? The graphics of the intersection between the two types of walls?
2025-01-30 05:56 PM
Yup exaclty, I need to put a thin line between two types of walls
2025-01-31 01:08 AM
I was going to help you with some pictures of the settings, but I can't get ArchiCAD to run on my computer anymore.
Something is stopping me from being able to run any files. It opens the start window but then locks up. ??
2025-01-31 02:14 AM
Are they Basic or Composite walls? If it is a Composite, is the end line turned on for your brick wall?
| AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2025-01-31 08:20 AM
they are composite walls here is how I want it:
I found a way if i make the interior line thin I can just add a thick line but its not automatic as it should be
Im also posting my wall settings if its helps someone solve it.
