Niranjan Das Sharma
Evoking Distance guide
Is there a way I can evoke distance guides? It sometimes pops up, sometimes it does not!
Operating system used: Mac Apple Silicon Sequoia
2 Solutions
There is something about a slab that is making certain walls be ignored by the distance guides.
Go to post
It is the slab cover fill that is affecting it.
Turn it off and it all works as expected.
Except for the objects, I can't get them to have distance guides.
Go to post
19 Replies 19
CosminF
Make sure that:
1. They are turned on - Options - Work environment - More options - Experimental features - Enable Distance Guides.
2. They are toggled on, you can add the toggle on the toolbar: https://help.graphisoft.com/AC/27/INT/_AC27_Help/030_Interaction/030_Interaction-65.htm
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Niranjan Das Sharma
I am using Archicad 28. it has the feature inbuilt and should be working properly. I have  distance guide is enabled but very un predictable.
Thanks
Niranjan
If they are active, it depends on how far you zoom in or out.
The elements the guides snap to have to be visible on the screen.
If you still have trouble, show an image of your distance guide settings, or even better a short video of the problem.
Niranjan Das Sharma
Check these screenshots. Same zoom. I don't see a distance guide when I grab the WC or a particular wall but another wall is showing up the guide.
   Also attaching the screenshot of settings
 Thanks Niranjan
I would suspect that that wall is not exactly vertical.
If the walls are at a slight angle, the distance guides will not lock to them.
Niranjan Das Sharma
Its 90 !  dont know whats wrong!
Niranjan Das Sharma
Also the other objects. They too dont show the guide when moved.
That wall may be vertical but then the others are not.
They all need to be perfectly square to each other.
Niranjan Das Sharma
 All are perpendicular. Windows and doors also not showing up the guides! Something wrong with the file it seems. I made a new file with default template and current profile and its showing up. I copied the elements and pasted it in the new file and it has problem!
