2025-01-28
		01:50 PM
		2025-01-30
		12:09 AM
Is there a way I can evoke distance guides? It sometimes pops up, sometimes it does not!
Operating system used: Mac Apple Silicon Sequoia
Solved! Go to Solution.
2025-01-31 08:12 AM
There is something about a slab that is making certain walls be ignored by the distance guides.
2025-01-31 08:21 AM
It is the slab cover fill that is affecting it.
Turn it off and it all works as expected.
Except for the objects, I can't get them to have distance guides.
2025-01-28 02:25 PM
Make sure that:
1. They are turned on - Options - Work environment - More options - Experimental features - Enable Distance Guides.
2. They are toggled on, you can add the toggle on the toolbar: https://help.graphisoft.com/AC/27/INT/_AC27_Help/030_Interaction/030_Interaction-65.htm
2025-01-30 06:25 AM
I am using Archicad 28. it has the feature inbuilt and should be working properly. I have distance guide is enabled but very un predictable.
Thanks
Niranjan
2025-01-30 06:32 AM
If they are active, it depends on how far you zoom in or out.
The elements the guides snap to have to be visible on the screen.
If you still have trouble, show an image of your distance guide settings, or even better a short video of the problem.
2025-01-30 11:58 AM - last edited on 2025-01-31 02:44 AM by Barry Kelly
Check these screenshots. Same zoom. I don't see a distance guide when I grab the WC or a particular wall but another wall is showing up the guide.
Also attaching the screenshot of settings
Thanks Niranjan
2025-01-31 02:48 AM
I would suspect that that wall is not exactly vertical.
If the walls are at a slight angle, the distance guides will not lock to them.
2025-01-31 05:46 AM
Its 90 ! dont know whats wrong!
2025-01-31 05:55 AM
Also the other objects. They too dont show the guide when moved.
2025-01-31 06:13 AM
That wall may be vertical but then the others are not.
They all need to be perfectly square to each other.
2025-01-31 06:42 AM
All are perpendicular. Windows and doors also not showing up the guides! Something wrong with the file it seems. I made a new file with default template and current profile and its showing up. I copied the elements and pasted it in the new file and it has problem!
