a week ago
- last edited
a week ago
Is there a way I can evoke distance guides? It sometimes pops up, sometimes it does not!
Operating system used: Mac Apple Silicon Sequoia
Solved! Go to Solution.
a week ago
There is something about a slab that is making certain walls be ignored by the distance guides.
a week ago
It is the slab cover fill that is affecting it.
Turn it off and it all works as expected.
Except for the objects, I can't get them to have distance guides.
a week ago
Make sure that:
1. They are turned on - Options - Work environment - More options - Experimental features - Enable Distance Guides.
2. They are toggled on, you can add the toggle on the toolbar: https://help.graphisoft.com/AC/27/INT/_AC27_Help/030_Interaction/030_Interaction-65.htm
a week ago
I am using Archicad 28. it has the feature inbuilt and should be working properly. I have distance guide is enabled but very un predictable.
Thanks
Niranjan
a week ago
If they are active, it depends on how far you zoom in or out.
The elements the guides snap to have to be visible on the screen.
If you still have trouble, show an image of your distance guide settings, or even better a short video of the problem.
a week ago - last edited a week ago by Barry Kelly
Check these screenshots. Same zoom. I don't see a distance guide when I grab the WC or a particular wall but another wall is showing up the guide.
Also attaching the screenshot of settings
Thanks Niranjan
a week ago
I would suspect that that wall is not exactly vertical.
If the walls are at a slight angle, the distance guides will not lock to them.
a week ago
Its 90 ! dont know whats wrong!
a week ago
Also the other objects. They too dont show the guide when moved.
a week ago
That wall may be vertical but then the others are not.
They all need to be perfectly square to each other.
a week ago
All are perpendicular. Windows and doors also not showing up the guides! Something wrong with the file it seems. I made a new file with default template and current profile and its showing up. I copied the elements and pasted it in the new file and it has problem!
