a week ago - last edited a week ago by Laszlo Nagy
I'm freshly new to Archicad and I ran into a problem where i need to have wall connected to perimeter wall and in my country in should look like in the second picture.
So its the "clean up" that your not happy with. Is that correct? The graphics of the intersection between the two types of walls?
a week ago
Yup exaclty, I need to put a thin line between two types of walls
a week ago
I was going to help you with some pictures of the settings, but I can't get ArchiCAD to run on my computer anymore.
Something is stopping me from being able to run any files. It opens the start window but then locks up. ??
a week ago
Are they Basic or Composite walls? If it is a Composite, is the end line turned on for your brick wall?
a week ago
they are composite walls here is how I want it:
I found a way if i make the interior line thin I can just add a thick line but its not automatic as it should be
Im also posting my wall settings if its helps someone solve it.
