grey materials render with pinkish cast ArchiCAD 11
i found it. emission colour looked like it was black but it was not quite.!
3 Replies 3
Dwight
that will be your sun and/or ambient light colors as set in the camera tool/sun dialog.
Or bad calibration.
Dwight Atkinson
my screen is calibrated so it must be light settings. when i choose gray (on my screen) as the base colour, the preview shows it pinkish (dramatically). i will check the sun... thanks
Thomas Holm
Same issue here. And on the floor plan too (which isn't rendered at all). So it can't be the sun. But I'll check some more.
Edited: I just did. It really looks like there is a pinkish tint to gray colors when I publish from Archicad 11 to PDF. (I mean the colors 92 etc. in the old AC9 etc color table). They are supposed to have equally balanced RGB values and should print gray.
I guess this has something to do with color profiles. Does anyone know if Archicad's output is color profiled any way?
