‎2006-04-17
03:32 PM
‎2023-05-11
12:33 PM
Noemi Balogh
‎2006-04-17 04:35 PM
heynock wrote:It depends on the door. Some have settings that allow them to be animated. This requires setting the appropriate parameters in the door to the frame numbers of the flythrough during which to open the door. When you run the flythrough be sure to check the box "Rebuild Model for Each Frame".
1. how can I see the doors open at a moment the camera reaches
2. I got a great rendering image output to my model using Lightworks,LightWorks must be selected as the rendering engine in Options > Photo Rendering Settings. When you create the flythrough be sure to select "Photo Rendering Window" rather than "3D Window".
However how can I use that rendered output in making the flythrough movie.
‎2006-04-19 01:04 PM
heynock wrote:Here are some example HERE, but i think it is in Poland language
You need to download Animation Door LIBRARY at www.archogdan.cadea.pl
‎2006-04-19 11:17 PM
‎2006-05-01 11:33 AM
