Visualization
how can i adjust transparency in lightworks?
so when i play with the materials options under ligthworks...i only have the option for color. how can i change how transparent the material is? also...even if i choose white as my transparency the material still appears white. thanks for the help.
Make sure when editting materials to have the Lightworks Rendering Engine option, (not Internal Engine or OpenGL) then all the shader settings will be there in front of you: Colour, Reflectance, Transparency, Displacement, Texture Space, and Pipeline. If you are starting with an existing material its probably a good idea to click on "Match Internal Engine" to get started, and then modify as necessary.
Dwight
Here's how to most easily adjust transparency, based in percentages. "Plain coverage."
If you wish to use color as a transparency metaphor, use the "plain" shader.
Dwight Atkinson
