import from archicad to artlantis
Hi, i have a problem importing the archicad 17 file to artlantis 4.1..
I export the archicad file as I usually did before with older versions of archicad..when it comes to open the artlantis file, it says "the file cannot be loaded", why does this happen?
6 Replies 6
There are separate exporters for 4.1 and 5. Are you sure that you selected 4.1 format when saving from the 3D window?
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
yes I selected the 4.1 version in perspective view of AC.
the problem appears when it comes to open the atl file, it says that file cannot be loaded,
when i open the atl file it looks like this
Mystery. Have you tested with a fresh project and just a single wall, for example? I've not heard of anyone having an issue.
Check the Artlantis Import & Plug-In forum for more help:
http://www.artlantis.com/_forums/viewforum.php?f=15
the results are the same, thanks anyway , I will try to fix in an another way,
vfrontiers
I do NOT know what the cause is (or the fix, for that matter)… I do know that I had a similar issue and my WORKAROUND was to save as 3.x and open the 3.x in 4.1… Once there, it will be a 4.1 document…
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
