‎2007-08-08
01:35 AM
‎2023-05-11
12:25 PM
Noemi Balogh
‎2007-08-08 03:12 AM
‎2007-08-08 04:50 AM
TomWaltz wrote:It makes sense. I guess this brings me to my next question....Can the distribution of frame sets (0-100, 101-200 etc.) be set from within archicad (my main machine) so that the render jobs be divided unto the render farm? (like 0-100 gets rendered in computer 1, 101-200 in computer 2...etc).
Sort of.
When rendering the walk-through, you can render each frame to an image file (JPG, TIF, etc). With that logic, you can set each machine to render a range of frames (like 0 to 100, 101 to 200, etc).
You would then need a video editor (I like Quick Time Pro) to assemble them into a movie file.
Does that make sense?
‎2007-08-08 05:37 AM
junior wrote:From memory (I haven't done this for about a year, and it was in V9) you have to set up the rendering on each seperate machine - so open master copy on each computer (copied to home drive/off network to be extra safe). Then go into rendering settings of each instance and change the range of frames you are rendering.
Or will I have to run a different instant of archicad per range of frames?
TomWaltz wrote:Or iMovie on your mac.
‎2007-08-08 07:15 AM
Tom wrote:Thanks for the info. And thanks for bringing the possibility of teamwork being involved in the process. Its worth experimenting with.
I don't know if you could do something clever with teamwork? but with only 5 computers it's not to strenuous to set up each one indiviually.
Tom wrote:I didnt know iMovie could be used as an assembly tool. I should look into this.
‎2007-08-08 11:03 AM
junior wrote:Yeah - however i have no idea where you'd start, as i don't really use teamwork. would be interested to see how you go though.
junior wrote:I find it heaps easier to drive than Quicktime Pro, and having a mac, you already own it (not that QT is going to break the bank.)
‎2007-08-08 05:52 PM
Tom wrote:When I come to it, I will definitely return to this thread with the status of my findings/progress and most likely more questions. I am currently putting my flagship computer together and I have 2 computers in my render farm (still need to setup though). I plan to acquire 3-4 more scrap computers in the upcoming month which will hopefully complete my render farm.
‎2007-08-10 11:16 AM
‎2007-08-10 06:11 PM
stefan wrote:I admit, I may have to explore other software to do what I intend to do. I personally like to keep the number of applications I use to a minimum..but still willing to explore better possibilities.
Most other software supports render-farms. Some even allow distributed bucket rendering (rendering parts of an image on different machines).
