lwi extension
We all have a bunch of files that end with the extension "lwi" in the Lightworks folder as part of the ArchiCAD Library. With Google I found out that this is an image format for Lightworks. How can I use these in ArchiCAD or can I?
Thanks,
TIM
David Maudlin
Tim:
They can be loaded via the Materials... dialog box when set to LightWorks Rendering Engine > Load Settings from Archives (these same type of files that are in the ArchiCAD Library 14 > Lightworks 14 folder). These will only effect the materials in a LightWorks rendering. As Dwight has pointed out, the implementation of LightWorks in ArchiCAD is incomplete, so I don't know if any/all of the settings in these files will carry through to ArchiCAD.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
