Want Transparency off in Internal engine Hidden line View
What is the process to get the Transparency turned off for an Internal Engine Hidden Line View?
3 Replies 3
Rod Jurich
Open this window to select your settings Jay.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
David Maudlin
Jay:
And once it is set, select the View in the Navigator, open the View Settings dialog box, in the 3D tab check the "Redefine Image Settings with current" to save this setting as part of the View.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I had done that.
It took Opening and Closing View for it to "stick" for me.
Simple but elusive
