perspective rendering in hiddenline
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-10-06
06:32 PM
2023-05-11
12:30 PM
Noemi Balogh
2006-10-06
06:32 PM
this will be in all in black and white and I want straight lines,
I can use plotmaker to do that import the 3d generated view and it will be fine, but I want to correct some of the lines before I print, so I use photoshop for the imported pdf or jpeg format.
I do corrections, I save the file as jpeg or tiff anything, but when I import back to plotmaker, I loose quality.
If I save as pdf, I can not open in plotmaker. (I need to open in plotmaker because I have some templates there)
So here is what I can not do.
I want some kind of vector graphics format, after i can make touch up revisions, so it will be a single straight line, pdf would be fine, nut that doesn't work with plotmaker, jpeg is ok but it is only raster, poor quality.
I need something like floor plan drawings but in 3d window.
Anybody can help?
Anyfile format that you know work with photoshop and plotmaker and a vector file at the same time?
thanks in advance
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-10-06 07:34 PM
2006-10-06
07:34 PM
Fro 3D window after completing Internal Engine Hidden Line view: Save As
Archicad 2D Lines
Archicad 2D Lines
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-10-06 08:27 PM
2006-10-06
08:27 PM
well that is for plotmaker I presume,
I can't open 2dl archicad 2d lines in photoshop.
Before printing I want to edit some in photosop. I need a vector graphics file format like pdf.
but I cannot open pdf in plotmaker.
so if 2dl supports both photoshop and plotmaker,
can you explain me the work flow that I should follow
thank you
thank you
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-10-06 08:38 PM
2006-10-06
08:38 PM
Open the 2dl in a new instance of Archicad for editing vectors.
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-10-06 08:56 PM
2006-10-06
08:56 PM
Thanks a lot Dwight,
you know your way around man
appreciate that
appreciate that
