Visualization
problem with rendering
hey guys, im having a problem with rendering things, actually now im doing sun study using just two cameras, the point is that when i start rendering or even fly-through the info box comes up with "not enough memory to render the model" can someone tell me what im doing wrong, and what memory is that about,
thx sooo much, Matt
1 REPLY 1
Dwight
Even though all those computer boxes look more-or-less the same on the outside, the amount of RAM inside determines the size of job it can do.
It is possible that Archicad can face a situation where constructing the model into a 3D file [prior to rendering] can cause the machine to over-demand resources. Typical problems:
1: Spanish tile roof. Solution: Don't do Spanish tile roof.
2: Corrupted illogical element - perhaps you ignored a warning about consistency during the drafting phase. Solution: systematically isolate the problem by cutting the project in parts with the marquee and layer visibility, then render.
If it is a small model, the problem is most likely a corrupted element.
Dwight Atkinson
