Visualization
"Photorealistic" objects in open-gl view. A question.
Im trying to make photorealistic objects to view in the opengl view. It almost works but I has some errors in the corners. Has archicad any limitations in the size of poligons that can texture? Can it be a problem with the normals?
Many thanks, Jose.
Uploaded with ImageShack.us
Dwight
The mapping control is the problem. Some shapes just don't work.
Dwight Atkinson
Import from sketchup and the mapping should be OK.
