Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Visualization
Render your model with built-in or 3rd-party solutions
render elevations and plans
how can i render elevations and floor plans, using lightworks as well as the sketch engine?
3 REPLIES 3
Dwight
Use the camera to establish parallel views instead of perpective views.
Plans are trickier - you need to estabish the view in parallel and then use the cutplane to slice off the top of the room.
Dwight Atkinson
How do I go about that? I am having trouble getting the parallel view set up for every elevation, it only seems to want to work for north and south ones. Is there also no way to do a sketch rendering of the floorplan as a plan rather than a view? Such as one that shows what you would see in a 2d plan view (ie door swings, symbols rather than objects, etc)?
Dwight
See attached for parallel view control.
To make a sketch of the floor plan:
Fastest:
Save the project with a new name.
Explode the plan into drawing primitives.
Make a new line type that is squiggly.
Select all the lines.
Apply the new line type.
Oy buy ArchiSketchy from Cigraph.
Dwight Atkinson
