Visualization
sketch rendering
hi there
I face a problem in my sketch rendering,I am using Archicad 12 educational version,but when I want to have a sketch render the result is a white sheet with nothing drawn,what is the problem? what should I do now?
21 REPLIES 21
Have you accidently set the pen colour to white in the sketch render settings perhaps?
Also check the camera position is not 'inside' a piece of geometry. Unfortunately it will look fine in the OpenGL 3d window so you can't immediately tell, but will render blank.
Link
Lots of things could cause this.
One way to help solve it is by checking the contents of the 3D window, as this is what the rendering engine uses.
Then is the size of your render window bigger than the sze of your 3D window?
Link.
I did all but the problem is still exist,please help me I have a big project and I'm in a hurry.
Dwight
Have you tried other rendering sizes?
Dwight Atkinson
yes but nothing happen
why dont you answer me? Im in trouble...please help me, i cant use sketch rendering...what should I do now?
The forums have been down for a couple of hours so that probably accounts for the quietness!
Maybe attach a screen shot of the sketch settings.
Possible ideas -
- Is ArchiCAD fully up to date?
- Does the sketch engine work on other projects, or is it just this one?
- Can you open up the project on a different machine and render sucessfully?
- Are there too many polygons? Select just a few objects and try to sketch render those.
- Can you sucessfully render using the lightworks engine?
- Have you tried a different setting for the sketch engine - different sketch and line styles?
- Have you set the partial rendering setting at the bottom by mistake?
- Are you using a white pen set, for use with a black background on plan?
- Contact your local reseller?
- Last resort - Have you tried reinstalling ArchiCAD? I'm not sure of the consequences on the education serial code, so check first with your reseller.
I'm out of ideas, Masoud! Sorry!
Here is your answers,please help me
Is ArchiCAD fully up to date? yes it is
- Does the sketch engine work on other projects, or is it just this one? it doesnt work either onther projects
Yes I can,I just have a problem with sketch rendering
yes,but with small object there is still rising problems
yes,I can
I tried all of them but nothing happen
no its on factory settings
no I use black pen
I reinstall it but the problem is still bothering me
please help me...
