Visualization
sketch view of the plans, elevations and sections,
heey i found out about the 3d projection settings that can enable me to view the 3d projection using different techniques such as sketch, is there is another way to add such an efect to plans, sections and elevations?? pls reply i really need your help thanks
NandoMogollon
Hi Hunya
Yes, there is a couple of ways to have a similar effect on plain drawings.
None of those is a single click - or a standard option on the section - elevations settings. So re-consider the option if you are in a hurry.
Option 1. Rendering an Object made of the floorplan / section / elevation.
Option 2. Rendering a paralell projection combined with marquee and Cutplanes.
Which way do you want to go?
Nando
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
hey nando,
thanks for your quick reply i really appreciate it
considering that i would choose option one cause i understand it how can this be accomplished?? i mean how can i treat the plan as an object and then render it?
thanks again..
