Visualization
some OpenGL questions
hello
i would like to know how do i create a new materials-list
so each time i wanna apply a material, it would give me only my materials and not all of the existing ones.
also, is there a way to avoid giving a material to a wall for instance, and then give it a material for open gl presentation ?
cya
6 REPLIES 6
Dwight
Materials are managed through the attribute manager, but there are many objects that call materials in the default list.
My suggestion is to not delete the existing materials, but to make new materials with a single letter space in front of the name so they appear at the top of the list - this makes them easy to find.
All objects must have materials, so this "Avoid giving a material" i do not understand. Please clarify…
Dwight Atkinson
hi
thanks for the first answer - good idea
what i meant in the second question is, is there a way to avoid linking regular, object material showing in the object proporties, and just use the material for rendering or open GL presentation showing in the attributes window.
hope i meade it clear.
oh and mary xmas for all u christians (:
Aime
and same to you too
Have you seen the light?
AC 12, AC14, win 7, Hp pavillion dv6 2.4Ghz, 4gb Ram
hope nobody gor offended - i realy meant mary christmass (:
thing is im jewish .
Stress Co_
Then ..... a Happy Hanukkah to you.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Aime
none taken.really wishing you a merry christmas.
cheers
