tree and people billboards
I'm relatively new to archicad, using the AC 8 student version, and I have pretty much no knowledge of gdl. Heres my problem: I need trees and people in my renderings. I followed the tutorial on the archicad online help for using the alpha channel with the picture command and found that although i could get the transperency, the shadow was just a rectangle. I then looked at the tutorial to do it by using a rectangle 'cutout' but i got confused when it said "We need to adapt the Master Script from the Cutout object" and then it had a whole lot of script. i also skimmed over the tutorial for doing it as a cutout but i couldnt work out how to do that seeing as i have already cutout the background in my images in photoshop. Can someone please help me? the deadline for my work is in 10days!!!
8 Replies 8
that problem have been talked already here in the forum, well for me that's a bug, a really bug never solved by graphisoft, like a simple "rotate 3d" never included in archiCAD and i don't know why.....it's so needed.
regards
The answer is here, from David Nicholson-cole
http://archicad-talk.graphisoft.com/viewtopic.php?p=16620&highlight=tree+shadow#16620
Great tip.
More recently from David, take a look at Chapter 9 in Introduction with Object Making:
http://download.graphisoft.com/ftp/publishing/ac9_help/wwhelp/wwhimpl/js/html/wwhelp.htm
Even though this is part of the 9.0 documentation, you will find it useful in 8.... and you can see our very own Matthew Lohden get masked and manipulated! 😉
Karl
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
thanks a lot for the help, its most appreciated. This is a little off topic, but can anyone here tell me how to make my billboard objects turn to face cameras? i know its in the gdl cookbook but i really am running out of time
Hi Neil, try this in the 3D Script;
dx = GLOB_EYEPOS_X - SYMB_POS_X : IF dx = 0 THEN dx = 0.001
dy = GLOB_EYEPOS_Y - SYMB_POS_Y
azi = ATN(dy/dx) ! azimuth
ROTz (-90 + azi - SYMB_ROTANGLE) ! place face to camera
ROTx 90 ! stand up
ADDx -A/2 ! axis rotation
POLY_ 5, ! facette
DEL 3
Good luck for the deadline.
In addition, better to put "dx, dy and azi" definitions in the Master Script.
Then you can use the same routine for 2D Script.
ROT2 (-90 + azi - SYMB_ROTANGLE)
LINE2 -A/2, 0, A/2, 0
CIRCLE2 0, 0, A/2
DEL 1
hi olivier, i dont really know anything about gdl, (im going to learn soon) but i keep getting an error with that script. im assuming im supposed to just paste it below the script i got from your link for the shadows you posted earlier. It seems to have a problem with the line above 'DEL 3'
Thanks a lot for your help, i know im probably trying to do something a little bit beyond me, but im going to have to know these sort of things sooner or later
Hi Neil, seems you have less than three transformations of coordonates in your script.
I just made an example for French users, look at it, i hope you will understand.
Replace the image's names by your own, and adjust the pixel's dimensions for each image.
Be sure that your images are loaded with your library.
