Visualization
vr object, archicad 15?
upgrading from archicad 10 to 15- how do i save my model in a vr object so that my clients can watch the 3D model using QuickTime?
Graphisoft discontinued QTVR support in AC 13:
http://www.graphisoft.com/downloads/goodies/AC13/QTVR.html
You can create animations in 15, but cannot create QTVR panoramas or objects.
The 'substitute' is the BIMx format and viewer... but for AC 15 and 16, BIMx was an extra-cost license:
http://www.graphisoft.com/downloads/bimx/bimx15.html
BIMx is included as part of the AC 17 and newer licenses:
http://www.graphisoft.com/archicad/archicad_17/faq/
You can still generate QTVR using Artlantis Studio.
(I'm not sure how you upgraded from 10 to 15... there aren't any upgrade paths that don't go completely to the present... unless you bought someone else's license to AC 15?)
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
thanks.
the "upgrade" was me starting to work at an office using the 15 version
shiml wrote:
thanks.
Aha! šŸ™‚
