At a minimum Folders NEED to be hierarchical and should display as every folder structure in AC or CAD program
- For Example:
- A Rhino upgrade only costs $500US around every 14-16 months so it should not be a money issue.
- This is what we got
- Missing options:
- Using Folders to control visibility, priority, lock, properties? . Main problem with this is that a layer can only reside within one folder so this has to be implemented in the Layer Combination side.
- Click to rename Layers needs to return
- Select All - Unselect All, Lock - Unlock, Hide - Show buttons need to come back.
