Ability to Determine if an 'Empty Opening' (Door) acts as a Zone Boundary
Lee Hankins
It would be great if 'Empty Door Opening' could have a property to determine if it acts as a property boundary or not. When placing an Empty Opening (Door) in to an existing wall to create an opening between two existing spaces it would be great if the zone could spill through the opening if it were determined not to be a one Boundary so the two existing spaces become one new space.
1 Comment
As a workaround, you can tell the wall to not be a zone boundary.
Of course that means the entire area of the wall will be included in the zone area - i.e.the wall to the sides of the opening.
You would have to split the wall either side of the opening if you want super accurate areas.
Status
Open
with 19/200 Votes 10.526315789474%
