It would be very useful to have a function that allows users to copy selected pens from one Pen Set to another within the same Archicad file.
In larger templates, different Pen Sets are often used for different drawing scales, for example:
These Pen Sets usually share the same color logic and pen descriptions, while only some pen weights differ depending on the drawing scale.
Currently, if a new color or a new group of pens is added to one Pen Set, the same RGB values and descriptions often have to be entered manually into every other Pen Set. This is time-consuming and can easily lead to inconsistencies.
In the Pens & Colors dialog, it would be useful to be able to:
An additional option such as “Copy colors and descriptions only, keep target pen weights” would be especially useful for scale-dependent Pen Sets.
This would:
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
