It would be beneficial to see the advancement of schedules for elements other than doors and windows, such as beams, columns, slabs, and other assorted objects or designing elements.
Improvements such as,
ArchiCAD has implemented some of these customisations in window and door schedules, but hasn't extended the same curtsey to other elements, this development would allow for object schedules to be done in ArchiCAD, and detailed element schedules to go to steel (or other) manufacturers, along with a more accurate element schedules for builders.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
