ArchiCAD 28.1.0 Mac Silicon User Here -
Our typical workflow of saving off PDF files from Layouts involves selecting the layout (or multiple layouts) from the navigator, hitting CMD+P or File->Print, and then using the 'PDF' button at the bottom left of the window. In the next step, we typically create a new folder with today's date and provide a file name for the said PDF. However, we cannot use the keyboard shortcuts CMD+C or CMD+V to copy and paste the text. Instead, we have to right-click the text and select Copy/Paste. Is there a reason that keyboard shortcuts are disabled when saving files?
We would love the ability to keep using keyboard shortcuts on the save file window. Thank You.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
