From Archicad 28 onward, the opening lines are fully controlled by the Model View Options (MVO).
This change introduces some limitations, as it removes the ability to customize these lines individually for each door or window.
All settings are now globally applied, reducing flexibility in detailed design adjustments.
Some users rely on individual adjustments to manage visibility or distinguish between existing and new conditions in floor plans, elevations, and sections.
For example, existing doors are often shown without opening lines, while new ones include them.
This distinction is no longer possible in Archicad 28, as all opening line settings are globally applied through the Model View Options, nor there is a possibility to adapt this in the renovation filters.
So, it would be useful to bring back this possibility, or to add it to the renovation filters.
Thank you!
