Built-in Image Editor for Basic Adjustments (Transparency, Saturation, Levels, etc.)
Pedro Melo
It would be incredibly useful if Archicad included a basic image editing tool for adjusting placed images — whether added using the Image Tool or the Drawing Tool — without needing to switch to external programs like Photoshop.
Proposed Features:
This wouldn’t need to be a full-blown editor — just a lightweight set of essential adjustments available directly within Archicad, applicable to both image-based Drawings (e.g. PDFs, JPEGs, PNGs placed via the Drawing Tool) and Images placed via the Image Tool:
  • Transparency / Opacity control
  • Brightness / Contrast / Levels
  • Saturation / Desaturation
  • Color overlay or tint
  • Crop and scale in-place
  • Convert white to transparent or simple background removal
  • Basic blend modes (e.g. Multiply, Screen, Overlay)
These settings could live in a contextual "Image Adjustments" panel or under the settings dialog for the selected image/drawing.
Why This Is Valuable:
  • Improves Visual Control on Layouts: Whether it’s a faded background sketch, a logo, a reference image, or a title block PDF, users often need minor adjustments for better presentation.
  • Eliminates Back-and-Forth to External Software: A simple opacity or brightness tweak shouldn't require opening Photoshop or another image editor.
  • More Flexible Documentation: Especially helpful when preparing layout sheets or diagrams where visual clarity and hierarchy are critical.
  • Consistency Between Tools: Whether you place an image with the Image Tool or as a Drawing, you should have the same basic graphic control options.
1 Comment
Daano
Your are correct Pedro. I in my opinion, since we work visual, it should be a full blow editor, easy to use. Sort of Procreate.
Being able to make / design things personal should get priority above enhancements like automatic dimensioning with AI. Being able to make personal work is for both the architect as Archicad important since that is the unique selling point.
Status
Open
with 24/200 Votes 8.333333333333%
Wish details
Labels
