Category linked Zone as Schedule fields
Olivier-IDAO
I would like to have the possibility of using the parameters: Category or Category code of linked zone as Schedule fields.
It is already possible with Name and Number linked Zone so why not with Category?
5 Comments
You can already if this is what you mean.
Olivier-IDAO
Hi Barry,
No it is not what I'm looking for.
The schedule is looking for objects and I want to know the Zone Category or Zone Code Category where are those objects.
So I'm looking for the Zone Category (or Code Category) linked name (I'm not sure of the translation) like it is already possible for the Zone Name or Zone Number.
See my screenshot (Archicad French version)
Ah, I see.
Your first post didn't say you were scheduling objects.
I assumed you were scheduling the zones.
Category and category code are not available for objects, so your wish remains open.
Olivier-IDAO
Thanks,
It would be a good one to add in the futur. 👍
Andrew Swenson
I have created a Schedule that is a "Zone Legend" showing the Category Name and Colour of the zone which I am using to show my Development Application zones to show which areas of the building require car parks.
My issue is that it shows all zones unless I add another criteria to the schedule.  I would have liked to use the Zone Category Code as I have used that to identify all the Development Application Zone Categories but it isn't available as a Schedule Criteria.
Instead I have used Zone Name as the additional criteria to show only zones on a layer that has the DA related zones on it.
It would be helpful if the Zone Category Code could be selected as a Schedule Criteria option.
Status
Open
with 0/200 Votes 0%
