Composite, Surface and Building Material codes
Toni Mayerhofer
Surfaces, composites, profiles, complex profiles etc. All these properties currently have a 'name' field that can be called up in a label. I would like a secondary 'code' field to be available for each of these properties that can also/instead if be called up, like the ID for windows and doors.
Then, we can label materials or composites drawings by code (eg. PF01, WT01) and search, edit and apply using proper human name (Paint Finish 1 - White Matte, External wall type 1 - brick cavity). They can be labelled intuitively instead of using text formulas, can be used in schedules etc.
1 Comment
Franz und Sue ZT
This wish already exists ... at least partially
IDs for Surfaces - Graphisoft Community
Status
Submitted
with 6 Votes
