Curved segments for Curtain walls
Karel Landa
Another wish that I have posted in the old Wishforum (I think) but did not make it here.
Curtain wall is a great tool for catering not only patterned facades but also to solve some parts of model where library objects are not good enough (eg. Door/Window). But the limitation for now is that if the reference line or boundary of the Curtain wall is curved, it is segmented based on the scheme of the CW.
On the first picture, in Edit mode, frames are segmented if I make curved boundary of the scheme.
On the second picture it is visible forced segmentation based on the scheme.
We need a possibility to set if it is supposed to be segmented or curved.
PS: I'm aware of an workaround where I can set the the scheme to be more dense and then in Edit mode delete unwanted parts but that creates too much elements in the project and I can not correctly schedule panels.
2 Comments
runxel
Probably GS thought that this does not exist in Real Life – but alas! it does!
Yes, it might be costly, but it is used.
Even more so since we need to abuse the CW tool for many other things, like suspended ceilings, where the boundary is now in the XY-plane and OF COURSE there are rooms with round walls... so, yeah. 😐
Jackson Han
There are cases where system windows are not composed of simple straight lines but require curves. However, the curved window in the Archicad library have limitations in modeling. In addition, the drawing representation is not natural. I hope this feature will be added.
Status
Submitted
with 21 Votes
