Custom Door Leaf: Stretch Modifiers
Guru
Hi all,
Everyone has seen the Stretch Modifiers for Complex Profiles right? Being able to define a vertical and horizontal stretch boundary. Imagine if when saving a Custom Door Leaf / Panel from the floorplan, a window popped up allowing you to define these boundaries. If you have multiple sizes for the same style, you most likely will not need a seperate Custom object for each. The edge trim will not widen because you set the boundary offset from the outside. The sash will stay at the same height and width since you set the boundary above it.
Ling.
re. Patricks custom door leaf collection...
Status
Submitted
with 14 Votes
