Decimal and Thousands Separators Should Be a Project Setting (Not System-Dependent)
arcade
I would like to request a change regarding how Archicad handles decimal and thousands separators.
Currently, the decimal separator (dot or comma) and the thousands separator (dot, comma, space, etc.) depend entirely on the operating system regional settings (e.g. Windows Control Panel). This creates significant workflow issues when working on projects in different languages.
In many offices, it is common to work simultaneously on:
  • English projects (e.g. 1,234.56)
  • European projects (e.g. 1.234,56 or 1 234,56)
At the moment, switching between such projects requires manually changing the Windows regional settings every time we switch projects. This is impractical and error-prone. It also makes it very difficult to ensure that all workstations in an office are configured consistently.
Suggested improvement:
The decimal and thousands separators should be defined at the project level, ideally within:
Options → Project Preferences → Dimensions (for example inside “Dimension Preferences”)
This would allow:
  • Different projects to follow different numeric conventions
  • Proper consistency in team environments
  • Elimination of dependency on OS-level settings
  • Reduced risk of documentation errors
Number formatting is part of documentation standards and should belong to the project configuration, not to the operating system.
Thank you for considering this improvement.
5 Comments
runxel
I agree. Getting this kind of info from the OS was never a good take.
Hopefully we see it rectified in the future.
Guru
Why any setting in AC is OS dependant is a real wonder...
runxel
Haha, adding "fonts" to that mistake!
What else is OS dependent? 🤔
JeffH
Yes to this request..and the fonts as well.
I also wish that the Working Units settings could be treated the same as Project Preference Dimensions where we can store different settings.
We have some minor issues with certain views, that if we make adjustments, it negatively affects other items in our model...Being able to assign that value from view to view would really help squash those issues.
2D
Date format is also OS dependant. Default colors are also OS… the list goes on.
Status
Submitted
with 28 Votes
Wish details
Product
Labels
