Design Option Combinations in Drawing Manager
Design Option Combinations should be a column in the Drawing Manager.
9 Comments
Decumanus
I agree, and each option should have possibility to set its own color of Fade Environment, AND it should be visible on layouts... I had to use graphic override...
This is a great feature, but it look like not entirely implemented.
R
James B
Hi Jared.
Thanks for the comment, we had some technical limitations/constraints in adding the Design Option Combinations as an extra column to the Drawing Manager, but are investigating ways how to do it.
James B
We didn't want to duplicate Graphic Override functions, but offer a workflow of being able to quickly fade what you're not actively working on - so more similar to Trace.
furtonb
Can you set the Design Option Status for drawings?
It looks to me that you can't and they are always part of the main model (as are hotspots which is weird).
jl_lt
Ace
That could work. And color coding!
can a  hotlinked module be in its own set?
Hotspots and drawings can't be part of a Design Option, which is annoying.
And able to be shown as a trace reference
If a Design Option is part of a saved view, that view can be used as a trace reference.
James B
Status changed to: Under consideration
Thanks for the feedback on this. As mentioned, we need to handle some of the technical challenges, which can also help other developments in the future that may need to be added to the Drawing Manager too.
I've moved this to under consideration.
Status
Under consideration
with 54 Votes
Wish details
Product
Labels
