Dimension and Group Zones for Feasibility designs
Anyone out there does Stack models for quick feasibility studies?
I am sure there are plenty.
For something like below, the last thing you need, is to draw walls and slabs and roofs etc.
All you need is Volume and Space.
Why? Because at the early stage the model needs to be simple and nimble. Something easy to modify on the fly.
In order to do that, the less elements you have, the better.
Still, you would want to be able to get information out of the model, like:
  • Total Number of Apartments
  • Number of 1, 2 or 3 Bed units
  •  Gross Floor Area, Net (at least calculated) Floor Area
  • Breakdown of areas per Use/Category
  • etc
Also, sometimes you would want to do some colour-coded 3Ds right?
The Zone tool would be the logical solution to do these tasks, but:
  • We can't have associative dimensions to Zones
  • We can't Group Zones
WHY??????
Just because of these fall-backs, I use slabs instead. That is not very intuitive, is it?
Another use case for Zones, where grouping and dimensioning would be great to have is at space planning.
I personally do not design walls to start with, I design spaces.
Walls are just drawn in once the space planning is settled.
Like in the below sketch phase, when things are a bit all over the place, but coming together for space planning.
Again, dimensioning and Grouping zones would be an easy answer, but no, I have to use fills or slabs instead and turn them into zones later...
Yes, I understand that my design methods may be a bit unorthodox, still I find it would benefit many users if Zones were not an afterthought (Annotation), but a Design Tool.
Just imagine this:
If Zones were not necessarily defined by bounding walls, but instead, the Walls were defined by the Zones, how much easier, better and more automatable the design process could be?
In the future I am thinking of a workflow where
  1. we draw the spaces we need to define spaces and connections
  2. set up rules like:
    • If Boundaries of Zones that are in the Apartment Zone category align (touch each other) -> add an Apartment Divider Wall Type
    • If an Apartment Zone and a Circulation zone share boundaries -> add a Corridor Wall type
    • If a Zone boundary has nothing touching it or it touches a Balcony boundary -> add an External Wall Type.
    • etc.
Before we get to the above "Dream" stage though, we could just start with making it possible to Group and Dimension zones!
After all - just think about it - what is the difference between elements produced by the Zone Tool and the Slab Tool? Not much, right? So why could zones not be dimensioned and grouped?
Ps:
Please don't come back and say that "Design Intelligence initiative is going to do all this wonderful schematic designs for you..."
Maybe it will, maybe it won't, however Archicad already delivers 90% of what is required for a quick feaso, so why not add that extra 10%?
No need to make it super smart. Usable is good enough. 🙂
4 Comments
GG_rakurs
Auto-dimensioning for zones is really a needed thing, and not only in the earliest of stages of design like you're using it. It pains me that I cannot have associated annotations (dimensions) but I have to use "real" elements to have functioning and dynamic layouts for permits showing areas and volumes.
nonpertutti
Hi, happy to read that I am not the only one designing that way. And just as well as you, I happen to waste a large amount of time fixing dimensions and reselecting zones for no reason.
Designing with spaces in early phases - though it is but the tip of the iceberg of the software’s functions - is something that makes me think that Archicad is a comfortable designing tool (sounds like this year’s slogan in GS home page). To put it in another way, this is the kind of things I proudly show to Autocad users while I do it.
Any improvement on this matter would be very welcome, starting with @Karoly Horvath‘s suggestion.
@nonpertutti
FYI, Just because Archicad does not allow me to fully utilise Zones, I trick the system.
  • Use slab to represent Space
  • Classify Slab as Space
  • This way you can group, dimension SEO etc.
  • Create Properties to mimic Zone Category for colouring and for scheduling
While this fudging works all right, it is not intuitive and users get confused.
SimSmi1
I also use 3d zones as building blocks for feasibility, but I can see ArchiCAD concentrating their efforts on Design Intelligence initiative, in an attempt to keep up with the other  AI concept design tools
Status
Submitted
with 18 Votes
Wish details
