Possible bug?
When editing a dimension string which has custom text between two nodes, the default reverts to the measured value and hides the custom text. The default should remember which part of the string has additional custom text applied and show it.
The current default is resulting in frequent missing information on drawings.
Provide the ability to:
- automatically change text to EQ / EQ - maybe a checkbox of sorts?
- automatically add centerline object to dim string - currently requires using the object and placing it repetitively which is time consuming
- preset the dimension tool to dimension to one side of core only (framing) by clicking on the wall, similar to how it dimensions both sides currently. It is standard to only dimension to one side of the framing in the US, and although you can do so by manually dimensioning by skin, this requires a lot of zooming and on complex assemblies this can lead to inaccuracies. It also takes far too long. The other way it has to be managed is by dimensioning to both sides of the core, then manually deleting one side's dimension which is very inefficient.
