Door Details, Casing
Brad Norris
It would be wonderful if there was a way to create custom profiles for door casing.
5 Comments
David O
Yes I totally agree, the majority of my work is interior design & I end up having to add separate architraves, there should be options for plinth blocks & architrave blocks as well
Tim Ball
Maybe the frame and architrave profiles could be similar to curtain wall elements and railings where you can create your own profiles
tcurtis
Agree!  I end up using profiled beams and columns to make my casing.....labor intensive to do for each door.  And if a door moves or changes size, I have to update the beam / columns.  If I could simply choose a profile for the casing it would be amazing and a huge time saver!!
Magdolna Marosvari
Status changed to: Under consideration
Thank you very much for your suggestion. To manage expectations, please note that this wish is currently under consideration.
Status
Under consideration
with 40 Votes
Wish details
