Door/Window distance to adjacent wall parameter
2D
Apart from picking the left, center or right positioning option an additional parameter which would allow checking and adjusting (if needed) the distance of the closest point of a door opening to the closest adjacent wall would be handy. Allowing the property to be modified via a Property Value exchange would be great, as mentioned in a different wish.
Change/Exchange GDL parameters via Property Values... - Graphisoft Community
2 Comments
In version 28 you have distance guides.
Makes it super easy to adjust the position of the door/window.
Does that suit your needs?
2D
Hi Barry,
this works great per instance. However if it were an object attribute/parameter you could set the parameter globally (to multiple instances) and or filter/check for doors where a certain distance to an adjacent wall is not met.
It could also act as a "rule" - minimum distance to closest wall - door placement, if the user would decide to have such a rule.
Status
Submitted
with 0 Votes
Wish details
