I would like to have the option to group all the Element ID's in one cell, based on the Type reference or Orientation. For example, in the image attached I have 7 doors of Type 1 that open on the left and 2 that opens on the right.
I would like to be able to add a row which displays all the ID's for that type of door in one cell. If I add now the Element ID as a field, it further breaks the doors into individual columns, which is not nice to see if you have over 100 doors.
Adding them manually in a Custom Text row is also very time consuming and might also lead to errors.
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0 Votes
