Embed an image in a dwg
Thomas Nymann
Hi GS.
On behalf of our clients I wish that the possibility to embed an image into a dwg, when exporting such from AC, would be a possibility.
Kind regards
Thomas
4 Comments
Just to clarify a bit: so, when a DWG is saved from Archicad, it is currently possible to save images as well. These images will be saved into the same folder where the DWG file is saved. If I understand correctly, you would like all these images to be embedded within the saved DWG so one does not have to make sure they send the images along with the DWG file (which they may forget)?
Thomas Nymann
Hi Laszlo.
You got that perfectly right 🙂
Cheers T.
jStrada
Any update on this?
The only thing we know for sure is that this wish is still Open, and in the last 10 months, it gathered 10 votes.
Status
Submitted
with 14 Votes
