Far from origin warning
NBGsteffen
Hello!
It is a well known fact that there will be trouble if you have scattered elements/objects in your Archicad-file - Far From Origin - Troubleshooting Guide - Graphisoft Community
In Solibri you have a warning if you open an IFC where this is the case - Widely Scattered Models – Solibri Desktop Help Center
Is it possible to implement a similar function for Archicad?
For example:
  • A warning when you import something and it is FFO
  • A checking tool that locates and identifies problematic elements/objects
Status
Submitted
with 25 Votes
