Floor plan view setting consistency
Patrick M
would love to see some consistency here:
21 Comments
@Lingwisyer
Regarding All Relevant and the Cut Plan Range, it does not take into consideration what storey something is on. This means that you can get elements below showing through above, requiring you to reduce their Display Order, which then impacts the Display Order of the element on it's home storey, etc...
All Relevant is also impossible to use on sloped sites. The work around of splitting Views is impractical when you have dozens, if not hundreds, of ground floor levels. The only way to get things to show properly is to set every wall to Home Storey Only with the display set to Symbolic Cut.
I couldn't agree more.
Status
On roadmap
with 172 Votes
Wish details
Product
Labels
