Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Graphic Override styles to access properties
Josh Verran
This might be best explained through an example.
Imagine if you had a property that contained the embodied carbon of an element (kgCO²/kg).
Then you had an expression-based property that converted the kgCO²/kg to an RGB value.
Not sure exactly what that would look like, perhaps R = kgCO²/kg x 50, G = kgCO²/kg x 10, B = kgCO²/kg x 75.
Concat Expression R & G & B.
The end result would be a graphic override that could on the fly change the colour of an element based on its Embodied carbon.
At the moment you need as many GO rules as there is values.
Endless other applications
Hope that makes sense.
5 Comments
Professor Pickle
I would go even further than this. Elements should be able to have their properties set by reading other elements' properties. Combine that with expressions and you're in parametric haven 😉
Miha_M
One element properties belong to that element, I wouldn't expect further interaction with other element's properties on this level. But I would love to have the schedules overhauled into something with interactive expression functionality.
Professor Pickle
I want the ceiling in my secret torture chamber to always be at exactly 1.3m above the medieval torture rack. If I can read the properties of the torture rack then as I move it around the chamber and adjust it's hight to suit the heights of my variously vertically challanged henchmen, the ceiling will automatically move up or down to keep the overall depressive atmosphere of the chamber.
neilmcallister
That's not the exact use case I had, but pretty similar.  Muaahaahahaaa!
It's similar to the Conditional Formattin in Excel where you can define a Color degradation.
This option could be actually used to any Graphical override and It would save tons of time because:
- Only one Rule would be necessary for euch graphical override ... because the colors would be decided by the system.
- In the early design stages you just want to visualize the differences quickly, and not needing to see how many values you have and deciding a rule and color for each different value ... that will change very quickly as the Design moves forward ... word for nothing.
I hope this helps
Gabriel
Status
Upvoted
with 39 Votes
Wish details
