Problem: In Archicad 27, the library contained Imperial structural steel sizes (sized in inches). As of Archicad 29, the sizes in the USA template are only metric.
Solution: The Archicad 29 USA Template's Library should contain Imperial beam and column sizes.
Has anyone else come across this issue?
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
with 0/200 Votes
